How do I publish a survey with repeats that do not have an associated field in a related table?
148
07-16-2020 08:01 AM
I need to be able to publish a survey (from a non-federated feature service) that uses a feature class with a related table (streets (parent)-->Inspections (child)).  The related table fields are successfully publishing as a repeat within the survey.  I need to be able to create a separate repeat (or multiple repeats) that would be 'null' values to use the outcome in the relevant fields in the table.  Is there a way to do this?  I keep getting the error "The custom feature service submission url is not compatible with this survey (Table AlligatorFakeRepeat not found)."
Is this possible?
Reply
I should add that I assume this would require the 'nested repeat' functionality, but I cannot figure out how to overcome the issue of having a repeat for a field that isn't actually in the service, but just acts as a function for adding up decimal values.
Leah, I'm having the same issue.  Were you ever able to figure this out?
Reply
