How do I display time on a DateTime question when viewing data on survey123.arcgis.com?
346
09-28-2018 07:25 AM
RobBlash
I have a survey with a DateTime question. When I look at the data on https://survey123.arcgis.com the date is displayed, and you need to select a record then look at the popup pane on the right to see the time.
Is there a way to also display the time in the column?
JamesTedrick
Esri Esteemed Contributor
Hi Rob,
Thanks for the suggestion - I've filed an enhancement to enable date/time display.
ZhifangWang
Hi Rob,
The enhancement has been implemented in the 3.1 release, you can now see the corresponding format for date, time and datetime question in the table of the Data page.
Thanks again for your feedback.
RobBlash
Excellent, thanks for the heads up. Looks good to me
