How can users simply Read sent surveys?
647
06-28-2017 11:45 AM
DougBrowning
MVP Esteemed Contributor
I have users asking how they can View surveys they sent.  When they go into their sent box and tap a survey it asks to edit or copy to a new one.  They do not want to do either then just want to "Look at" the one they sent.  So they get confused and I end up with double data or date stamp changes.
Is there any way to just view in the app?
I am guessing the answer is - that what Collector is for.  But if you collect a survey offline then collector can not help you.  Our guys might be a few days with no internet so no way to sync the survey then sync to collector.
Any ideas appreciated.
Thanks
Tags (3)
JamesTedrick
Esri Esteemed Contributor
Hi Doug,
Thanks for bringing this up.  We wouldn't necessarily say that reviewing the survey data that has been submitted is a Collector activity; when used in tandem with Survey123, Collector's role is more focused on map-based browsing of the data.  Certainly users can open the data in the sent folder, either in the edit or copy mode, and then simply exit out without submitting data; however, you raise a good point on simply wanting to view data.
