How can I recover a survey in survey123 online after deleting the Fom file from ArcGIS online?
2637
6
05-12-2017 05:58 AM
AshrafAfana
Hi all,
I've deleted the #Form file of one of my surveys from my ArcGIS online, which directly removed my survey from the #Survey123 online. I still have the host feature layer in arcGIS online. How I can #recover that survey?
Ashraf,
JamesTedrick
Esri Esteemed Contributor
Hi Ashraf,
You can recreate the survey using Survey123Connect - select 'Add New > From Feature Service' while logged in as the owner of the feature service.
AshrafAfana
Hi James,
Thanks for the reply. This will recreate the project but the original data that has been collected will not appear with the new recreated project. So, in survey123 online you'll have the survey but with 0 collected entries. Although I still can see the data in arcgis online, but I would like to see it in survey123. Any suggestions?
Ashraf,
CarmelConnolly
Hi Ashraf,
Can you use ArcGIS Pro to append the original data to the new feature service?
Append—Data Management toolbox | ArcGIS Desktop
Carmel
AshrafAfana
Thanks Carmel,
Unfortunately, I can't install ArcGIS Pro on my laptop, work policy.
Very appreciated.
Ashraf, cheers
JamesTedrick
Hi Ashraf,
Using the submission_url setting, you should be able to configure the survey to write data in the old survey's tables.
AshrafAfana
Thanks James,
This was really helpful. Although I struggled to find out about the url submission in survey123, but with little search in the net I managed to found something.
Ashraf, cheers
