How can I modify Survey123 to make use of the Runtime Portal object?
383
01-11-2019 11:32 AM
MattStayner
Occasional Contributor II
I just learned over on this thread that Survey123 doesn't actually use the Runtime Portal object. I am modifying Survey123 in AppStudio and I need to be able to sync feature services, so I need Runtime.
Any recommendations on how to approach this? Should I replace portal or make a new object that uses Runtime Portal?
Matt
JamesTedrick
Esri Esteemed Contributor
Hi Matt,
This might be better addressed in AppStudio for ArcGIS‌.  That being said, my initial reaction would be having parallel portal objects- the Survey123 one and a separate Runtime Portal object.
JamesTedrick
Hi Matt,
MattStayner
Thanks James. I will take it up with the AppStudio forum.
