How can I edit a form created in Connect using web editor
1263
12-08-2020 02:12 PM
BrandonA_CDPH
Occasional Contributor II
I am looking for a way to edit a form created in Survey123 Connect using the Web Designer. I know this is not normally allowed because of different capabilities, but, is there any way to do that short of recreating the form(s) from scratch? I am hoping to get around some recent technical issues with remote work (they are on my side, not ESRI's) and use the Web Designer more. I like the access to bells and whistles though, so almost all of my forms were created with Connect. I can remove unsupported capabilities and change things around if needed, as long as I can use the web designer to edit moving forward.
Any advice/solutions that are not completely recreating the form in Web Designer (and moving the data into the newly created Feature Service, etc.) are appreciated. Thank you.
KrishV
Occasional Contributor III
Hi @BrandonA_CDPH ,
If you have to create in Web Designer, you need to start from Scratch. Please see the documentation below:
https://doc.arcgis.com/en/survey123/browser/create-surveys/publishsurvey.htm
Krish
KrishV
Hi @BrandonA_CDPH ,
Krish
BrandonA_CDPH
Exactly what I was afraid of.  Thank you for verifying that I didn't miss something.
JenniferMcKee__GISP
New Contributor II
put your survey in editing mode and use a webapp or a dashboard to to select a feature to edit. https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-embedding-a-survey...
