Hide all questions if a specific answer
96
10-26-2021 06:24 AM
LazellariEmerson
Hi all
I would like my survey to skip to the end if respondents give a specific answer. The function in web browser does not work very well and continues to show other questions. How can I do this on XLS format ? Any help with syntax?
For example selected(${question}, 'other')
                      ${question}='Specific Answer'
                       END SURVEY
CarolynShultz
It should be possible to do that in the web browser with some finagling. The set rule function works, but it's only supported on certain question types (single choice, dropdown, rating, and likert). If you can re-word your first question so that it fits one of those structures, then group the rest of the questions and set them to show for every answer except the one that will end the survey using the set rule function, then it should do what you describe. This is a potentially time-consuming solution, though. I'm sorry I can't help with XLS formatting.
LazellariEmerson
I want to avoid exactly that! otherwise I would have to write around 75-80 conditions...
