Help with rules/ schema
1265
01-12-2021 11:43 AM
JordanMassingill
Hello, I am trying to create a survey in Survey 123 and use rules on my first question.  I noticed that once I created the follow-up questions for the rules instead of the follow-up question data going into the same field, it is creating a new field for each question.  Is there a way for this data to go to the same field or is this something I will have to do manually after each survey is submitted?
My first question is "What Plant" and has three choices.  The follow-up question is "What System".  I set up the rules to show the systems specific to each plant to keep their option list shorter.  Instead of having one field in the schema for "System" I now have three.  Any guidance is appreciated. 
BarbaraWebster1
Hi Jordan,
You could do this by configuring a cascading select on a 'System' question. This would have to be configured in Survey123 Connect, but you would still be able to distribute the survey via the web app (as opposed to the field app).
Here is a link to documentation on cascading selects, and the download link for Survey123 Connect is at the bottom of this page.
-Barbara
BarbaraWebster1
Hi Jordan,
-Barbara
JordanMassingill
Thank you!
