Have a repeat in survey123 default to last record entered
179
01-21-2021 08:28 AM
TomBaldvins
Hello,
I am creating a form in survey123 that records plant species along different transects. It would speed up productivity a lot if the survey could default to the last species selected. Has anyone set up a survey like this before? I am trying to capture the last species collect in a text field outside the repeat, but I am getting the error below. I am attaching the survey below.
Thank you!
DougBrowning
MVP Frequent Contributor
Are you trying to do something like a Same as last button?  If so then no can't do it if the size of the value varies.  I created a page with a default values setup then it asks you Use Defaults?  Best I could do.  I posted on this but cannot find it in the new system.
I have been asking for the lists to auto sort based on the last choice for some time now.  A lot of this was talks with the 123 team or in the early adopter so I cannot link to them but this is one from 2018  https://community.esri.com/t5/arcgis-survey123-questions/how-to-random-sort-choices-in-a-question/td....
I see you say LPI in there.  I have a LPI form already as part of our program for a Fed agency.  Are you Fed by chance or work with one?  If so DM me and I can get you more info.
Also move your list to external choices and it will be much faster.
Edit just seeing some of this is coming in the new beta.  I will be testing this soon.
Hope that helps
TomBaldvins
Hello Doug,
Thank you for your response. I am currently working for a Natural Heritage Program, and work with several federal agencies. This LPI form is based on one we developed for some BLM aim studies. We are now trying to adapt it for forestry surveys.
Tom
DougBrowning
I am with the AIM team!  Send me a DM and I will just give you the form.  No need to reinvent it.
