Have a new repeat scroll to top
1516
7
09-14-2017 09:58 AM
Trippetoe
My survey contains a repeat.  Within the repeat there about 20 questions - enough so that the first question within the repeat is off the screen by the time the bar for adding a new repeat is visible. When a user adds a repeat, it would be best if the form scrolled automatically back to the top of the repeat.  currently it seems that the form actually scrolls to its bottom or doesn't move at all
Is there a way to have the form automatically go to the top of the repeat when a new repeat is added?
(i am using Survey123 Connect 2.3.24 and Survey 123 for Windows 2.3.29)
EDIT:
I just found this link (Adding record in repeat stays at bottom of group. ) asking the same question.  Has this feature been added to the release plan?
JohnathanHasthorpe
Hi Tom
I have added your request to our internal issue. It is currently in our backlog, but we will re-review it (due to the number of resent requests we have had to address it).
John
JeffVan_Etten2
Good morning.  Just was wondering if this request has been added to any future release plan for development or has this functionality been delivered yet?
Jeff
JohnathanHasthorpe
Hi Jeff, yes this has been implemented. If you add a new repeat you are taken back to the top.
JeffVan_Etten2
Johnathan
Thanks for coming back.  Where do we need to place the repeat?  The form already has repeats present, but is not returning to the top as required.
Jeff
JohnathanHasthorpe
Hi Jeff - can you share your survey? I'll take a look at it.
JeffVan_Etten2
Johnathan
Are you able to drop me an email so I could send to you?  The survey is pretty big and contains a lot of sensitive information.
Jeff
JohnathanHasthorpe
Please send it to: jhasthorpe@esri.com
