GUID is not saved
242
10-25-2021 04:39 AM
Jcordovafredes
Occasional Contributor II
Hello I tell you that I have a form with historical inspections, that is, it has a repeat and related tables
The point is that when I want to capture the information from the Mobile Survey123, the information captures me without any problem, but when reviewing the information in the corresponding attribute table, it is not capturing the GUID.
and this is relevant because there is a relationship Global ID with GUID
And I still can't find the solution
ABishop
Regular Contributor III
Jcordovafredes
Thanks, for the answers, but it is not what I am looking for, since the Global ID is generated before publishing the service and the GUID is a code associated with the Global ID, that is, every time I do a new inspection, it should generate me a GUID
ABishop
