Get Z (altitude) by Calculation or service?
1274
02-17-2022 08:50 AM
bryandhughes
I have a form that would be easy enough to add a Z property in the geopoint. However, doing so requires edit to the XLSform and makes it so the drag/drop designer is no longer functional.
Is there a way to accomplish something similar by getting altitude based on latitude and longitude in the Calculate field in the web-based designer?
Ideally getting the Z value would just be part of the default geopoint property, especially since the iOS app already retrieves it. But, that's another topic.
ThomasHamill
@bryandhughes, I'm not sure how to configure this in web designer, but in S123 Connect, there's a Sample form called 'Calculate Location from Geopoint' that shows this quite well.
Kindest Regards,
t
ThomasHamill
@bryandhughes, by any chance did you try to implement that with Survey123 Connect to obtain Z-Values from the tablet?
Kindest Regards,
t
AaronPDXPaul
I am trying to get the Sample Calculate Location from Geopoint. The Altitude field is not pulling data. Same when I try on my service. Has this feature broke, or no longer can get z value?
