Get the X and Y Values from the Map
1240
12-03-2020 06:36 AM
GeoHawaii
Hey All,
im new in the survey123 js api, and at the moment im trying to get the coordinates x and y from the map component.
im using onFormLoaded to get the Form. And with onQuestionValueChanged i wanted to get the x and y values, whenever i click on the map. But my problem is, the values in the questtion map are always null
	let webform = new Survey123WebForm({
		itemId: '...',
		container: 'test',
		clientId: '...',
		portalUrl: '...',
		onFormLoaded:(data) =>
			console.log(data);
			console.log(data.form.questions);
			console.log(webform.getContainer());
			OnQuestionValueChanged:onValueChanged(data)
function onValueChanged(data)
	if(data.form.questions[0].label === "map"){
		//here i wanted to do something like
            x = data.form.questions[0].value.x
            y = data.form.questions[0].value.y
Calvin_Jung
Hi
The `onQuestionValueChanged` event should be at the same level of `onFormLoaded`. For example:
let webform = new Survey123Webform({
  itemId: '',
  onFormLoaded: ()=>{},
  onQuestionValueChanged: onValueChanged
When you change the value in a map question, it will trigger the onQuestionValueChanged function (e.g. `onValueChanged`) and pass the following data to you which includes x and y.
  path: ''.
  formId: '',
  field: '',
  value: {
     x: 0,
     y: 0,
     spatialReference: {
       wkid: 4326
So your `onValueChanged` function should be:
  x= data.value.x;
  y= data.value.y;
GeoHawaii
thanks for the Reply, i tried to write it like
but my onValueChanged will not trigger. thats why i used it like this
		itemId: '',
		container: 'test',
		clientId: '',
		portalUrl: '',
        onQuestionValueChanged:onValueChanged
	console.log(data);
