Get location, date and more from from Collector in Survey123
1868
04-12-2017 02:30 AM
LeonhardStöckle
Hey there,
I'd like to know how far I can go with the url scheme to populate my survey. I already got simple things like ID and Creator figured out.
I would like to get the location parameters for a "geopoint" directly without a list.This way I could match new points in Collector directly with a Survey.
It would also be nice to get the {CreationDate} from Collector in a "date"-type in Survey.
Also it would be interesting to match my data from Collector with a "select_one" in Survey.
Is any of the above possible?
Thanks in advance
Leo
JamesTedrick
Esri Esteemed Contributor
Hi Leo,
The center parameter will supply the location for a geopoint question:
center=<latitude>,<longitude>
ex: center=37.8199,-122.4783
You can find out more at Integrate with other apps—Survey123 for ArcGIS | ArcGIS
and at Understanding Survey123's custom URL Scheme
LeonhardStöckle
Ok, cool. Neraly there.
The coordinates you use are seperated by a point (center=37.8199,-122.4783) but ArcGIS displays points with a comma instead (37,8199,-122,4783)
This leads to an incorrect output at the geopoint. This center=37.8199,-122.4783 turns out as center=37,81.
The only thing I found to chance this it to set my seperator is in the settings of windows
Do I miss something obvious? I tried to change the comma to point in ArcGIS in my {ESRIGNSS_LATITUDE} and {ESRIGNSS_LONGITUDE} attributes but it didn't work.
JamesTedrick
Leonhard - can you review this GoeNet post: https://community.esri.com/message/637513-re-app-linking-of-decimal-values-not-working-correctly ?  This sounds like the same issue, but with a different flavor.  Can you verify that your URLs have comma decimal separators instead of period decimal separators (which wasn't the case in the other post)?
by Anonymous User
Not applicable
Is there a limit to the number of values that can be passed from the collector app into the Survey123 app? I was unsure if there was a limitation in the number of fields or the string length/number of characters for the URL within the hyperlink from within the pop-up window of the collector app into the survey123 app using an iPad.
