Geopoints in repeats
1053
07-20-2022 08:25 AM
SamGatter
Hiya,
I am struggling to incorporate a geopoint question into a repeat within a survey. The survey published fine and I am able to create multiple inputs per point, however when attempting to submit the survey I receive an error message 'JSONObject["objectid"] not found'.
When removing the geopoint question from the repeat there isn't an issue when submitting a survey.
I have also created a test survey to see if that has the same issue, but it works as intended.
Any help is greatly appreciated!
DougBrowning
MVP Esteemed Contributor
You need to post the form so we can take a look.  thanks
SamGatter
Hi Doug,
I have managed to solve this issue by removing the initial page of the survey, before I had two pages, one for an initial selection and then another for the repeat. When removing the first page (so it's all a one form with the repeat at the end) it works at intended.
It's quite strange as I couldn't find anything online about the same behaviour, and looking at guidance for S123 Connect it doesn't seem that this should be an issue.
DougBrowning
My guess is using the same field name twice, some reserved word, bad table name, or a bad calc.  That is why seeing the form would help.
I use multiple geopoint questions all the time so it is something else.
