Geopoint returning values from another geopoint in Survey123
169
08-27-2021 10:22 AM
Jcordovafredes
Occasional Contributor II
Let's assume I have 3 geopoints in my survey.
The first geopoint is the Alpha point so to speak.
I want both the second and third geopoints to return the same location as the first Alpha geopoint.
Is it possible to do that?
Try something like this is default, but with no result yet.
Jcordovafredes
In order to make a geopoint call another geopoint on the same map, it is necessary to occupy the coalesce function in the calculation column.
example:
coalesce ($ {STATUS_2}, $ {ESVAL_GIS.Events_1_point})
STATUS_2: has information in note
ESVAL_GIS.Eventos_1_point: is this geopoint that has the first localized point called "mother geopoint"
Jcordovafredes
example:
