Geopoint location not showing in feature class table
2073
7
01-06-2021 02:51 AM
CrystalCowardin
I have a Survey123 Connect xls form and it has a geopoint question with a map to search and pick a location.  When I'm testing the form, I can search by a location and click on the map but then when I review the results in the feature class, I don't see the field for the geopoint information.  Any help is appreciated.
DataOfficer
@CrystalCowardin do you mean the x and y values? You can store these as separate fields by adding rows to your xlsform with pulldata calculations. E.g.
where ${GeoPoint} is the name of your GeoPoint field.
CrystalCowardin
Thanks. I'm going to try that now.  For all of those fields, would the type in my xlsform be geopoint?
CrystalCowardin
pulldata("@geopoint", ${LimitedBroadbandLocations_v02_point}, "y")
This is what I've put in and keep getting this error when saving the form.
DataOfficer
What do you have in the relevant column for that row?
CrystalCowardin
I didn't put anything there.
CrystalCowardin
I had the calculate in the wrong field! Trying again.
CrystalCowardin
It works.  Thank you so much!!  I have 1 other question that you may be able to help me with.  On the survey, they are choosing a point on the map or they can search by address using the Geocoder.  Is it possible to record that whole address location, instead of the lat/long.  Thanks.
