Generating a polygon of a specific size on geopoint
341
07-25-2023 11:16 PM
JThornberry
Hi there,
I am authoring a Survey 123 app in Survey123 Connect for users to complete targeted bird surveys.
Essentially, I would like to use a geopoint/geoshape to generate a 2ha rectangle centred on the surveyor, which the surveyor will then use as a bounding box in which to complete their survey (records are collected in a repeat later on).
I realise that this is likely quite complex to achieve, but would be great to know if it is possible.
Cheers
