Form Logic Error uploading from connect to online
658
07-28-2022 07:37 AM
TonyaBonitatibus
Hello,
   I am trying to publish a survey created in Survey123connect and am getting the following message:
  • FormLogicError: Could not evaluate: /model/instance[@id="sampler_name"]/root/item[selected( /model/instance[1]/KYR_2_1/welcome/organization , organization)], message: Weird args (should be separated by commas):[{"t":"arr","v":[{}]},{"t":"bool","v":false}]
 I am unsure how to correct this error.
Thank you for any help! TB
DougBrowning
MVP Esteemed Contributor
You are using a ton of reserved words in here.  You must have somehow removed all the checks built in to excel.  Maybe copy paste.  Without these helpers it can be tough.
Look at the Reserved sheet in excel.  You have user, password, maybe appearance.
I would start by cleaning all that up.
Hope that helps
