Dear ESRI team,
I have to questions:
- First question when am using filtering in the map viewer for the field reporters i will get correct number of records that person sent it to us but when am trying on survey123 for web I will get wrong number of records, for clarifying my question I attached pictures shows that person send 16 records for us but in survey123 web shows 2 records.
- My second question is why i cant not see date field for filtering in the map viewer ?
Hi Rawand,
Just to confirm, is the 'Reported by' question a single choice question (has a domain)? I see 'zaenab' is used in the Survey123 query, while the ArcGIS Online table displays 'Zaenab' - if this is a free text box these represent 2 different values.
Dear James,
Yes, its free text field so to prevent this i should use single choice question ?
So what about my second question please ?
thank you
Rawand
Hi Rawand,
A single_choice field would ensure consistent entry; you also might want to consider a username question to automatically record the username. The second question deals with the ArcGIS Online map viewer? You should be able to see a date field in the list for filtering- can you provide an example of what you are seeing?
