File Attachment size is only 10MB?!
1358
02-21-2023 09:14 AM
JaviVasquez1
What's the workaround to increase the file size and when is ESRI going to increase this?  I have big documents on the way.  Thanks!!
Kepa
by Esri Contributor
Hello @JaviVasquez1
At least using Survey123 web app you can increase it up to 100MB. More info
Regards,
Edit: Also using max-size bind::esri:parameters property on Survey123 Connect
Kepa
by Esri Contributor
Hello @JaviVasquez1
Regards,
JaviVasquez1
That'll work.  Just have to recreate the form using web designer I suppose.  Thanks for the help!
MichelleWilliamsERM
If you are using Connect, you can also do this, but the files could be huge in AGOL, so this is a delicate dance.
