Field name length limited to 32 chars?
1024
06-15-2020 08:34 AM
DougBrowning
MVP Esteemed Contributor
When did this limit of 32 for a field name come in?  Anyone have any info?
Thanks
Hussam_AlJabri
* If you are using ArcGIS Online - The survey will publish fine.
* If you are using Portal for ArcGIS - The survey won't publish until you minimize the number of Chars to less than 32.
Hussam_AlJabri
Hey Doug Browning,
The Error of limiting in the field name is returning when you try to publish your survey to Portal for ArcGIS.
DougBrowning
I am getting the error in 123 before publishing.  I am not using Portal at all.
So do you mean it is a warning but will publish and work?
Thanks
Hussam_AlJabri
