Hi @CliftonSimmons2,
Can you confirm what iOS device/model and iOS version is being used? Can you confirm the default image format in use on the Camera settings of the iOS devices.
Also what version of Survey123 field app?
You are correct, Survey123 and ArcGIS Online/Enterprise does not support uploading HEIC images, therefore only supported formats should be selected.
Regards,
Phil.
