Field app- form doesn't fit screen on iPhone SE iOS 13.3
3102
01-09-2020 02:08 AM
לאוראורשן
New Contributor III
Hi, I'm experiencing a bug on reporting with iPhone SE. This did not happen before I used older iOS version.
I also looked at iPhone 11 and this bug doesn't happen.
Steps to reproduce the bug:
  1. Enter the survey123 app
  2. Tap on a form
  3. Click “Collect” button
Expected result: the form should be seen correctly
Actual result: the form is cut, user can't see the fields names
לאוראורשן
New Contributor III
BrandonArmstrong
Hello,
Which version of the Survey123 field app are you using?  If not using 3.7, can you please update the field app and let us know the results?
It would be great if you could also share your XLSForm if possible.
Brandon
לאוראורשן
New Contributor III
Thanks for prompt reply
The field application is version used is 3.7
Please find the xlsForm. It contains Hebrew ☺
Best
Laor
<http://facebook.com/Health.gov.il>
<http://call.health.gov.il/>
<http://health.gov.il/PniyotHazibur/Pages/CallCenter.aspx>
<http://www.health.gov.il/>
ד"ר לאור אורשן
מנהלת המעבדה לאנטומולוגיה
מעבדות מרכזיות, ירושלים
טל: 02-6551851 | פקס: 02-6551651
נייד: 050-6242382
Laor.Orshan@MOH.GOV.IL
BrandonArmstrong
Hi Laor,
Thank you for raising this issue, I can see the behavior that you outlined above.  If possible, it would be great if you could raise this issue with Esri Technical Support and have them log an official BUG .  This will allow you and others to track the progress of a fix and help the development team keep track of how many other Survey123 users are being affected.
We will updater this thread as well when the issue has been addressed.
Best Regards,
Brandon
לאוראורשן
New Contributor III
Hi Brandon
Thanks!
We opened support call through Systematics, Israel.
Best
Laor
ד"ר לאור אורשן
נייד: 050-6242382
