Feature Service is linked incorrectly.
430
12-12-2025 02:36 PM
HeathAnderson
Hi All,
I am looking for some help and perhaps @JamesTedrick or @IsmaelChivite could weight in on how to rectify my issue.  We have a Water Main Break Survey123 some data schema changed and cause a new feature service to be publish.  For the longest time this was okay.  Recently the script that creates and downloads survey123 reports has been failing with the error:
_stk_layers = self._stk.layers + self._stk.tables
TypeError: unsupported operand type(s) for +: 'NoneType' and 'NoneType'
As far as I can tell the script can't seem to get the feature service associated with the survey. I can work manually through the Survey123 website and everything works fine.  Which has me thinking that there is still a connection between the survey and feature service via portal.  However, scripted appears to be another story.
I have been working on ways to script around this issue but I can't seem make it work.  I would think that tackling this issues from a data administrative angle would be appropriate; given that the script had been working until recently, within the last 10 days.
Any help would be greatly appreciated.
Cheers,
Heath
