Feature Report - Nested/Nested photolog how to get the nested photos only for summited record?
1106
01-05-2024 12:31 PM
MichelleWilliamsERM
I need only to pull the photos in repeat for the latest submission.
I used this code in other surveys, but it's not working as expected here ${if (EIH_PhotoLog | getValue:"count")>=1}
In this survey, the daily report is a nested repeat, and the photolog is nested again; things got complicated here.
I've attached the .xlsx file and the feature report.
Here’s how to load everything if you need to work through it.
  • Publish with Inbox turned ON
  • AND turn OFF Sent Folder option
  • Complete two inspections; use the Inbox for the 2nd one.
  • Take a Environmental photo for each submission
  • Upload the feature report to AGOL/Survey123
  • And print
  • The photo prints for each (see PDF)
Thanks for any help you can provide.
abureaux
MVP Frequent Contributor
I have attached an XLSX. Your form was giving me anxiety with the names not typing in, so I had to move to a fresh template (sorry). But, I highlighted 3 fields that I added so you can see what's going on.
InspPosition is just your position within the main repeat.
EIH_position (hidden) is a copy of your position within the main repeat for the nested image repeat. This way, you know when a photo was taken in relation to the main repeat. EDIT: It occurs to me that you will likely need to enclose the value in once() so it doesn't update old values accidentally.
positionMax is simply the highest value of InspPosition (aka, the last repeat item).
In the feature report, just use this:
${#EIH_PhotoLog | where:"EIH_position = positionMax"}${EIH_Photo}${/}
That should only print photos from the most recent submission. Though, can't say I spent too long going through your form, so I may have missed some function. If so, please let me know.
