Feature Report map breaks when I add code | orderByFields:"ObjectID DESC" | resultRecordCount:5
203
04-23-2024 12:03 PM
MichelleWilliamsERM
I hope you're having a SPATIAL day,
I need your help!
The top image is a straightforward feature report with a repeat (DailyReport) and a nested repeat (PhotoLog).
The bottom image is the weekly report, and I want to pull data from the last five days.
It works for everything except the photolog map.
I get this error message
I tried adding another backslash but it didn't help.
Thanks for your help!
@Ismael I'm adding you and your magical team to this one.
2 Solutions
RobertAnderson3
MVP Regular Contributor
There seems to be an Esri side issue with geopoints in Report Templates for Survey123 right now, as seen here: Print fail started overnight - Esri Community
abureaux
This should be resolved now. I just did a test and things appear to be working again.
RobertAnderson3
abureaux
MichelleWilliamsERM
BLESS YOU ALL!
Thank you; it was just bad timing on my part.
