When submitting survey data via web form I'm receiving errors:
In Chrome — "Failed to submit. - Cannot read property 'json' of undefined"
In Firefox — "Failed to submit. - r.featureServiceJsons[e.id] is undefined"
Surveys were created in Connect. Submission is working from the Windows Survey123 app.
I've created test surveys from the advanced template with no changes and do not receive the error, so something in my questions is causing problems, though web submission has worked on these surveys previously.
Survey is here: https://survey123.arcgis.com/share/2f7003bd34c14d38b97d903e869ec644
Any ideas for how to get web surveys working again?
Thank you,
Steve
Hi Steve,
Can you please share the XLSForm that you used to create the survey? Also, please provide the version of Survey123 Connect that you used to publish the survey.
Brandon
Hi Brandon,
The survey was published with Survey123 Connect version 3.0.142.
The XLSForm used to generate the survey is here: RGWF RMYC v06.xlsx - Box .
Thank you!
-Steve
The online form appears to be working correctly again. Thank you.
Did you do something to make it work?
I am getting the same error. Frustrating vague. What should I look for to fix it?
