Failed to submit error in Survey123 Form
4857
14
12-13-2023 11:19 AM
DianaTorres10
My form was created using the Survey123 Connect version 3.18.123.
I have the following error when users try to submit an answer:
[{"id":0,"addResults":[{"success":false,"globalId":null,"error":{"code":10500,"description":"Database error has occurred."},"objectId":null}]}]
I'm using a pulldata calculation consuming a feature service.
I tried changing the feature service and also updating it's privacy.
Any advice?
RyanJensen18
Hi Doug,
Thanks for the quick response! Here is my xls sheet. It was working perfectly before the last update.
DougBrowning
MVP Esteemed Contributor
I would start by setting all those big table fields to bind::esri:fieldType null.
RyanJensen18
Thanks Doug, it worked! I am wondering why it was working before without the null value.  Either way, thanks.  I have another question.  I have a field in a survey that gets its data from a csv. I also have an inbox but the only field that doesn't show data is the csv file field.  It submits with data but when inbox is refreshed by a different user, that field shows no data.  Any thoughts?
DougBrowning
You probably got a bigger result in production than testing.
Yes coming back from inbox or drafts can create all kinds of issues with calcs.  You could try a calculation mode of when empty and see of that does it.  Never had much luck but worth a shot.  https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-calculation-modes/...
Also make sure your csv is clean - no extra commas or special chars.  Look at it in Notepad vs Excel.
I see you have the word query on the begin group line that I would remove.
RyanJensen18
Hi Doug. I figured it out. The survey that was having the issue was a submission_url survey and the calculation for that field was getting erased.  I removed the calc and it stores the data in the inbox. I will remove the query.  Thanks for your help.
