Exporting Survey123 Data to a Multiple Sheet/Tab Excel File?
411
04-15-2019 10:18 PM
EricShreve
Occasional Contributor II
Does anyone know if there is a workflow that allows for exporting a spreadsheet with multiple sheets/tabs if there are multiple pages created in the Survey? My example is that I have a five-page Survey that I need segmented during export into various excel sheets/tabs rather than having a spreadsheet with 50+ fields for one sheet/tab.
by Anonymous User
Not applicable
Hi Eric,
This is not currently possible. The export function is similar to that in AGO and Portal. You could try using Python or another scripting method to split up the exported data into sheets.
Phil.
EricShreve
Phil,
That is what I was thinking my solution was going to be as well. Thanks for the input!
-Eric Shreve
