Export a webform created in Survey123 to host on our own website?
404
11-20-2018 12:42 PM
DornMoore
Hi all,
I know we can create a webform in Survey123 to allow users to fill out the form and the data will be pushed to our feature service. Is it possible to export the source code of a webform created in Survey123 to customize and host on our own website rather than it calling an embedded form?
I understand this would "break" the connection between the exported form and the Survey123 Structure.
If not, it there a way for me to do something similar with WebApp Builder?
Or a good tutorial on building a webform with the ESRI JavaScript API (or something else more appropriate)?
JamesTedrick
Esri Esteemed Contributor
Hi Dorn,
We have an on-premises installation of the Survey123 website available in the Early Adopter Community, which would accomplish what you are describing.  We currently do not plan to release the web form as a separate web page.
DornMoore
Thank you for the response James. I've taken to coding it out myself to satisfy the needs of my field researcher.
I'm a big fan of Survey123 but in this niche area I needed another option. Thanks for clarifying that this isn't on the plate any time soon. Keep up the great work!
