Experience Builder with Survey widget
256
06-17-2025 11:53 AM
SanchezNuñez
Good afternoon,
Is there a way to digitize a polygon and use a survey widget to populate its attributes.
I am looking for a way to use a Survey widget inside EB because I want to populate some fields by default, that are located in lookup tables.
abureaux
MVP Frequent Contributor
In native EB and S123? I don't think so.
None of the EB widgets can feed data to S123, which is what you'd need. You can of course use the geopoint question in S123 to achieve that. Maybe this is more administrative than anything else, and structuring the EB workflow/layout to guide users to the survey for data entry could work.
