Error when sharing results of a survey in Survey123 web
767
06-02-2021 08:08 AM
WHOrATAAdminSupport
Hello,
I have created a survey in survey 123 Connect, and I need to be able to share the results with an existing group, as per usual.
However, this error appears and does not le me share the survey.
I have tried deleting and recreating the group, changing the name of the group, and nothing changes, I always get the error message.
Does someone know what to do to solve the issue?
Thank you,
Irene
Shwu-jingJeng
Please refer to this online documentation to see if you have meet the requirement to share the result:
https://doc.arcgis.com/en/survey123/browser/analyze-results/sharesurveyresults.htm
Pay attention to the Note sessions and confirm you meet the requirement.
Could you also try with other surveys to see if you can share the result with a particular group?
AlexandraLehner
New Contributor II
Did you ever find a solution to this? I am having the same problem.
