hi all, I have survey which include 3 question with images inside repeat.
my survey is based on existing feature class in SDE.
when i try to upload more than 5 images i get this error.
is there a limit to the upload?
Unfortunately, the error is not attached - did you mean to include a screenshot? To my knowledge, there should not be a limit to the number of images that can be uploaded.
Yes, I'm sorry this is the screen shot. Can you elaborate on the uploading limits?
Since I was uploading to a service placed on my server and not a hosted one I thought there is no limit at least not after 6 images.
In case it happens to anyone , I found the problem , I cant reproduce it or pinpoint why it is happening , but it keep occurring from time to time .
here is how to solve the problem:
The folder "My Survey Attachments" holds all the images that you takes whether you submits the survey or not .
when you get the error go to this folder you will find one or more images that appear as blank , they just missing the suffix ".jpg".
Once you edit the image name with the correct suffix you can submit the survey , if you still get the error remove the image from the survey and reload it ,this time it will have the correct suffix.
iris
