Error on summing up an indexed-repeat equation
394
03-25-2024 10:24 AM
DanaYoung
I'm new at creating equations in xls format and I'm struggle with getting this equation to function for a survey in survey 123.
I get this error in survey 123 : "TypeError: Value is undefined and could not be converted to an object in expression: sum(indexed-repeat( /Form_1/bio/biological_control_agent/bioamt , /Form_1/bio , position (..)))"
The equation is: sum(indexed-repeat(${bioamt}, ${bio}, position (..)))
The table below is a copy from the form I'm working with (maybe I don't' have the layout correct?)
Any help or insight would be greatly appreciated.
DougBrowning
indexed repeat returns just one value so cannot sum it.  If you just want to sum the values of the repeat simply
sum(${bioamt})
is enough
DougBrowning
sum(${bioamt})
is enough
DanaYoung
Thank you! Of course it's something simple, but then again I was coping this form used for a different application, so thought it would be similar in equations, but apparently not.
