I'm new to Survey123. When I attempt to publish my survey, error reads " Failed at checking the sources of the view feature service" If I attempt to publish again, error tells me my column names are duplicates. I have to go to each field name and change it in Modify Schema in order to publish. Using web designer. Thanks in advance.
Hi Amanda,
Thanks for the feedback. I'm thinking there may be another issue at play - BUG-000129358 in particular was seen in ArcGIS organizations that were seeing high feature layer request levels (typically organizations that held publicly shared content for a disaster response operation).
