Error converting XLSForm - Survey123 Connect 3.14 version
10823
23
03-23-2022 09:48 AM
AdriannaBarton
Beginning this morning we have been getting this error, "Error converting XLSForm" when saving an .xls form. It is happening when a field is moved, deleted, or a calculation is incorrect, and pretty much any time we don't save after making a small change. Typically where a detailed error used to be given it is just this message. Is anyone else having this issue today? We have 3.14 desktop connect, which we have been using for weeks so no new download on our end.
HuntingtonHabitatLuz
Saludos. Gracias
RodellZorilla
Hello, I have been getting the generic  "Error converting XLSForm" when saving as of this morning (6/8/22).  I have ArcGIS Survey Connect Version 3.14.281. Anyone else having the same issue as described by OP even after the fix? Thank you!
UPDATE: It appears that the error appears if I choose the types: select one or select multiple. I looked at the choice names and choices, but they seem appropriate (no spaces, special characters). Does anyone have an idea as to why the error is occurring? I appreciate any help.
SECOND UPDATE: OK, could be a rookie mistake. I left the field, "bind::type," blank for the Select One/ Select Multiple types fields. That resolved the issue in my case.
JoseBarrios1
Hello!  I'm also getting the generic  "Error converting XLSForm" after updating to 3.14.281. Does this still a bug???
JB
NourElHoudaAmhez
Has this issue been resolved from your end? I am still receiving this error although I am following the guidelines as indicated.
I appreciate your reply.
Thank you in advance.
Best!
Nour,
