ERROR 404 can't export with Excel any survey123
661
03-22-2023 10:26 AM
daudet84
Hello,
I am trying to export with Excel my surveys made with survey123 and I get an ERROR message saying that the page can't open. It is doing it with my recent and old surveys. I can't get the information out in an excel form... Is there a problem with survey123? It works if I export as CSV or geodatabase but Excel doesn't want.
Thank you
Richard_Purkis
Hi @daudet84
Are you using Edge? There was recently an update that was causing this issue when opening in browser. The workaround was to disable opening Microsoft files in browser. It only affects Microsoft Edge
Hope this helps
Richard_Purkis
Hi @daudet84
Hope this helps
daudet84
Yes, I tried with Chrome and It worked. Thank you!
