Embedding a portion of a ArcGIS Survey123 in a Story Map
89
01-19-2021 02:23 PM
MikeTresidder
I am creating a story map that has several sections where I would like to provide an opportunity for comment. and while I know how to embed a full survey, I'm wondering if it's possible to embed only a smaller section of a longer survey. I would like the respondents comments to be collected in one survey, and not across several surveys.
So if I have a longer survey for all the questions, but then in the story map, I only want to embed questions #1-3 at one point, and then later in the story map embed questions #4-6.
Thanks.
Reply
PanGIS
Here is the answer.
Read it through or look for the word 'hide'.
You will modify the survey view by modifying the URL parameters and them embed into your story map.
Hope it helps!
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-web-form-url-param...
