embed object ID into photos as a watermark
2531
10
12-26-2023 01:34 PM
EuropaxEarth
As the subject title suggests I'm attempting to embed the "objectID" into each photo as a watermark so that when that photo is downloaded as a report, the ObjectID will be visible.
I've been referencing the following document for help: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-photo-watermarks/b...
I think I could create a new field, text type question for ObjectID. But since ObjectID is an Auto-increment field, I assume there's another approach I've failed to consider.
Many thanks,
EuropaxEarth
EuropaxEarth
Based on your recommendations and this esri blog post
 I created a new integer datatype to return an integer reflecting the index in the repeat. In the calculations field I put in the following function:
position(..)
^ which returns the index of the current record in a repeat
Then I created a new calculate datatype. I need this to create a watermark ( it doesn't appear in the survey. It is very similar to a hidden question.) Under the calculation field, I did the following:
concat("Photo ", ${photo_num}, "&color=red&outlineColor=black&haloColor=white&size=26&bold=true")
Finally, under the existing image datatype, I scrolled over to the calculation field and typed in:
bottomLeftWatermark=${watermark} watermark="Lat: @[Latitude] \n Lon: @[Longitude]&color=red&outlineColor=black&size=26&bold=true&margin=10"
This creates two watermarks: the photo number and the coordinate point.
Thank you both for your assistance!
