Email regex isn't working for me, what did I do wrong?
575
04-12-2022 06:20 PM
Survey123Jedi
I'm getting this text populating 3.14 Survey123 Connect.
I haven't used the body::esri:inputMask in a while; what am I doing wrong?
I used the code from this post https://community.esri.com/t5/arcgis-survey123-questions/syntax-for-email-address-field-input-mask/t...
~ Michelle
jcarlson
The linked post states that the input mask won't take an arbitrary length expression. You need to put that expression into the constraint column.
- Josh Carlson
Kendall County GIS
