edit related table from ArcGIS online in desktop
1296
05-11-2017 12:51 AM
StuartMoore
So i've create a survey with a repeating section, when its published into ArcGIS Online it creates a point feature and a related table. what i want to do is append some data into both the point FC and the related table, but i cant seem to get be able to show / edit the FC & table in desktop.
firstly i tried opening the survey in desktop all i get is the point feature class, i then tried creating an online map with both the point class and the related table in it and then opening that in desktop as well this does show both the point FC and the related table, but when i try to 'create a local copy for editing' i get an error (screen shot below)
has anyone managed to get this to work?
thanks
JamesTedrick
Esri Esteemed Contributor
Hi Stuart,
Which Desktop product are you using?  For editing feature services, I would recommend ArcGIS Pro; ArcMap is much more limited for this task.
StuartMoore
Thanks James, I'm using desktop 10.3.1 but hopefully I'll have pro in a week or two so I'll try that
thanks
stu
