Edit mode is not possible because the record specified by the globalId parameter cannot be accessed.
224
03-17-2023 06:12 PM
MarceloCatalão
Can help me for used Report and experience builder
Richard_Purkis
Hi @MarceloCatalão
Thanks for getting in touch
It is difficult to confirm the exact reason why this error is appearing as there are multiple reasons why Survey123 is not able to access a particular record specified by a GlobalID.
In the first instance I would direct you to the following technical article:
If this fails to resolve your issue and you have confirmed the GlobalID is correct then I recommend you reach out to Technical Support.
Hope this helps
