Edit existing survey data photos are gone
998
06-08-2018 07:16 AM
CarlHolt1
Using the Inbox Mode where the filter is
MS4_EMAIL='yes'
but when users go to edit the existing survey the photos from the previous user are gone.
Screenshot of previous users survey where photo is now gone.
See pdf of submitted survey where Outfall Photo is present.
JamesTedrick
Esri Esteemed Contributor
Hi Carl,
Currently, attachments are not loaded and cannot be updated through the editing/Inbox process.
CarlHolt1
Are you saying that the image will still be present after the users edit the survey via Inbox? Do I just need to remove the Required=Yes from this field, because currently if I try and submit I cannot because there is no image for the required field?
How then do I get the users who are editing the survey to add a photo to a different image field? Currently the image field for the section of the Inbox editors is blank.
Different users making edit to survey via Inbox.
JamesTedrick
Hi Carl,
Yes, the image still has been submitted and will remain as an attachment after editing. For an editing workflow you would not want an image question be required.  We do not support adding an image as part of editing, even for questions that do not already have an image (there is an exception for adding a new record in a repeat section).
