Dynamic list from feature service works in web form but not Survey123 Desktop
2117
13
11-20-2024 05:23 AM
HanliePetoors
I'm working in ArcGIS Online
I have a survey that pulls values from an AGOL hosted feature service to a select_one question.
In the web form it pulls in the values and they can be selected:
But in Survey123 Connect and Survey123 for Desktop the values are not retrieved:
Any ideas why this might be?
Hanlie
HanliePetoors
Unfortunately the carrots did not fix this problem ;-).
I'm going to republish the service on a client's ArcGIS Portal and see how the operations fares there.
Regards
Hanlie
abureaux
MVP Frequent Contributor
BUG-000170893 When using a hosted feature layer from ArcGIS Online as the source for a drop-down question in the ArcGIS Survey123 web designer, the drop-down list is not populated in the ArcGIS Survey123 field app.
Should be fixed now.
HanliePetoors
Thanks, I'll have a look to see if it works now.
HanliePetoors
I've tested with two different services and it worked with the one but not the other.
Looks like I have a problem with the one service.
