Duplicate one image field to another image field
432
08-27-2021 01:12 AM
Muhammad_AzhaziqBin_Mohd_Azlan
Is it possible to copy images from one question to another question within the same form inside survey123 connect?
Background a bit, i'm building a form that will have repeat a image with text caption. The result of the form will be shown in experience builder list widget and I would like to pull image from attachment. Since the image with caption sits inside supporting layer, i cannot populate the attachment into the list widget since the list widget does not connect with the supporting table. Hence i'm thinking of while the user adding data in the repeat section, I will copy over the image into the main layer attachment.
Hey Alfred,
Great workaround. Unfortunately my layer published in Enterprise 10.8. I couldn't create a arcade calculated field in the table.
