Duplicate/Copy Group of Fields Not Working
727
02-01-2024 03:10 PM
ChristopherSakakihara
Hello all,
I am working on a Survey123 that uses the new Group feature, however, when I try to duplicate certain groups nothing happens.  The survey has a couple different groupings of fields and duplicate works for some of them but not all.  It seems to only work with my groupings that have less fields and those that do not contain Drop Down or Single Select type fields, does anybody know if duplicated groups have a limit to the number of fields or the types of fields they can contain??
Please let me know if any others have run into this or have an answer (haha might just be a bug that needs to be worked out)!
-Chris S.
abureaux
MVP Frequent Contributor
Groups aren't really a recent feature any more.
I am sure there is a practical limit to the number of items in a group/survey, but I doubt you are running into that here. For all intent and purpose, 'no' there isn't a limit. When you create a group, it should be visible in the survey. If you have 'pages' turned on and don't set things up properly, that can sometimes result in unintended appearances.
Can you please provide the XLSX?
