Drop down menu for decimal field in survey123 connect
876
05-23-2023 08:44 AM
AndrewSmeltz
Hello,
I am new to Survey123 using Survey123 Connect. I have a number field (Single) where it is only appropriate to enter data in increments of 0.5. Instead of entering a number, I would like a drop down menu to appear with the following options: 0.5, 1.0, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5, 6.
Is it possible to do this with a number field? The field data type can not be changed at this time.
Please recommend comprehensive resources, I'm new to this 🙂
Andrew
RichardPasquale
Can you use a "Select_one"? Having your defined responses be selections?
Katie_Clark
You can get a dropdown menu using the autocomplete appearance with select_one or select_multiple question types. By default, these question types are text, but you can use the bind::esri:fieldType column of the XLS form to force it to be a number type and it should let you convert without losing existing data.
Hope that helps!
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
