Downscaling full-res images in feature report
1194
03-07-2022 10:59 AM
MatthewAdam
I'm working with a feature report template and having issue with images coming in at the right size vs resolution. When the images are captured in Survey123, they are full-res at 1440p. Originally, I had the images push to the report with size: 450:450, but a client requested the images come in at HD. When I try to change the resolution to size: 1440:1080 the images come out gigantic. I have to then go in manually and resize the images which is fine for a one off report, but these are recurring. Is there any way anyone knows of to have the images come in at full-res but smaller physical size?
Attached is my report template for reference.
MatthewRogers
Hi @MatthewAdam ,
I believe you can use the following expression taken from the report template documentation.
"To display the original image at full quality but a set size, use the getValue and size expressions together."
${image1 | getValue:"" | size:450:450}
Hope this helps!
Regards,
Matt
MatthewRogers
Hi @MatthewAdam ,
Hope this helps!
Regards,
Matt
MatthewAdam
Thank you so much, Matt! This was the answer all along. I think I had misinterpreted the documentation at first, but this was clearly the answer.
-Matt
