Downloading Surveys in advance to edit offline
919
08-16-2019 08:21 AM
TomRuff
Is it possible to bulk download all surveys completed for a given area/entire survey dataset?
Currently my workflow involves downloading each survey individually and saving it as a draft so it can be edited offline later, However this could quickly become laborious if potentially hundreds of survey points need to be available to edit, similar to downloading a map in collector for offline use.
Tom.
BrandonArmstrong
Hi Tom,
The functionality that you are looking for can be accomplished by enabling and using the Inbox.
Take a look at the linked documentation for information related to the Inbox.
Prepare for editing existing survey data—Survey123 for ArcGIS | ArcGIS
Best,
Brandon
BrandonArmstrong
Hi Tom,
Best,
Brandon
TomRuff
Hi Brandon thanks for getting back to me. That's what I currently use but as far as I'm aware I can only download one survey at a time through the inbox. Is there a way to download all the surveys or are all the surveys downloaded automatically when you activate the inbox?
BrandonArmstrong
Are you the owner/creator of the survey?  If so, the default inbox behavior would be to download ALL records/surveys that exist in the survey/feature service.  It is only when specifying a 'WHERE' clause that it would be limited to a subset of the data.  Have you tried refreshing the inbox?
TomRuff
Okay, My apologies I didn't realise that if they were showing in the inbox (i.e when I refresh the inbox without a where clause) they are actually ready for offline use i.e downloaded to the device.
Thanks!
Tom.
